Home > Technical (L322) > Is this battery correct? |
Buellie Member Since: 28 Jan 2024 Location: Essex Posts: 144 |
11th Aug 2024 4:07pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7954 |
Just type 013 into Search
11th Aug 2024 4:39pm |
I think the 13 and 19 are the same from googling Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
11th Aug 2024 5:08pm |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 473 |
I have the same battery monitor and used it on my last FullFat (it’s now fitted to the F Pace).
11th Aug 2024 5:53pm |
Thanks Chris
11th Aug 2024 6:17pm |
Just looked again the cranking power is lower
11th Aug 2024 6:39pm |
Presumably that was one of the recommended ones for your reg number. I had the 3.6 TDV8 so I went for the H3 Varta, which is currently £112 plus delivery. Perhaps the 4.4 needs a different (and more expensive) battery 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
11th Aug 2024 7:01pm |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 827 |
yes the last 2010 models onwards TDV8 4.4 are better served with 019 AGM battery, even though it is not a "Stop Start" car, the BMS is able to charge it better when they have AGM batts in them - they cost more though approx £160 |
11th Aug 2024 7:22pm |
Giffer2018 Member Since: 25 May 2020 Location: West Yorkshire Posts: 60 |
Buellie,
12th Aug 2024 10:55am |
Griffey thanks for that info Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather |
12th Aug 2024 11:23am |
