Home > Maintenance & Mods (L322) > Overnight Jacking up Rear Wheel
pcourtney
Is the rear OK to be jacked up overnight using house bricks as shown in photo ?
It is in a locked up yard, so will not be pushed around by anyone overnight until the mechanic gets there in the morning.
Post #697552 7th Aug 2024 2:22pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
I wouldn't recommend that, bricks generally crack /shatter under load and the whole lot could just collapse.
Much better to use a HD axle stand or timber blocks if you have them. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #697553 7th Aug 2024 3:34pm
pcourtney
Thank you, in the end he managed to get a bottle jack under the suspension arm to raise the car a little more to get the spare wheel on, what we learnt is that you need to Lock Out the Suspension in Access Mode before you start messing around with changing wheels Smile
Page 90 of the 2011 user manual, Crawl Mode ( Locked Access Height ) , press the lower switch for longer than 3 seconds to lock the vehicle at "Access Height" , I think the idea is that this setting is retained in the computer memory and even if you turn off the car and lock it, it stays in a locked access height state.
Post #697556 7th Aug 2024 3:54pm
Paul H
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
page 242 of the user manual says to leave the suspension in On Road position...although if you go to a garage to get the tyres replaced they always ask for locked access mode, no idea why the differences 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #697571 7th Aug 2024 6:59pm
pcourtney
yes I saw that, its page 243 in my manual
I think suspension can only be locked in Access ( Low ride height ) mode, it cannot be locked in normal height, which does sort of contradict things a bit I guess !
Post #697575 7th Aug 2024 7:14pm
Paul H
I guess unless you are using a trolley jack you wont get any other kind of jack in place in access mode? maybe? possibly? 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #697576 7th Aug 2024 7:16pm
