![]() | Home > Technical (L405) > Restricted performance with cruise control on. |
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 132 ![]() ![]() ![]() |
Change the MAP sensor - it's very easy to do!
Tommybuk Member Since: 17 Jan 2024 Location: Ellon Posts: 13 ![]() ![]() ![]() |
Yeah, I've had that out to clean it. It was full of gunge!
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3195 ![]() ![]() |
my 4.4 TDV8 (l322) had this - it is to do with the sudden demand for fuel and air to maintain the speed uphill. on mine it was a cracked inlet manifold which led to RP. |
Ok, thanks for the reply. I'd heard the later 4.4's didn't suffer with the cracked manifolds, but who knows.
you're right they did change the spec for the later models. mine is a 2011. I think the 2012 on got the upgraded manifolds. Certainly the L405's did.
