Home > Technical (L405) > Restricted performance with cruise control on.
Tommybuk
Scotland 2016 Range Rover Autobiography SDV8 Barolo Black
2016 4.4 FFRR
Anyone had this?.......
'Restricted performance' when accelerating up a hill over 50mph with the cruise control on. It never does it with cruise off.
If I stop and start it again, its fine. It throws a code for the MAF, absolute pressure sensors
Its only done it about 3 times in 6 months....... No other symptoms.
Cheers! Thumbs Up
Post #697463 5th Aug 2024 10:06pm
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
Change the MAP sensor - it's very easy to do!
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #697518 6th Aug 2024 7:58pm
Tommybuk
Yeah, I've had that out to clean it. It was full of gunge!
Any idea why it only does it with cruise control on? Confused
Post #697519 6th Aug 2024 8:06pm
Dolphinboy
my 4.4 TDV8 (l322) had this - it is to do with the sudden demand for fuel and air to maintain the speed uphill. on mine it was a cracked inlet manifold which led to RP.
Post #697527 6th Aug 2024 9:58pm
Tommybuk
Ok, thanks for the reply. I'd heard the later 4.4's didn't suffer with the cracked manifolds, but who knows.
Hopefully if the fault gets more regular, the problem may be more obvious.
Post #697528 6th Aug 2024 10:05pm
Dolphinboy
you're right they did change the spec for the later models. mine is a 2011. I think the 2012 on got the upgraded manifolds. Certainly the L405's did.
My prob was ongoing for. few months - always at the same part of the M4 as it went uphill and CC was on. small crack spotted in the Pax side inlet manifold. £1600 to replace as the all the injectors need to come out and be replaced as part of the job.
Post #697578 7th Aug 2024 7:33pm
