![]() | Home > Maintenance & Mods (L405) > SDV8 Fuel Pressure Sensor |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2634 ![]() ![]() |
If you're replacing the sensor because of DTC P0088-17 then the cause is likely deteriorated wiring at an electrical connector for the sensor rather than the sensor itself, as described in LTB01083. |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 364 ![]() ![]() |
+1
Mike Stote Member Since: 13 Jan 2024 Location: Swansea Posts: 14 ![]() ![]() ![]() |
Thanks for the info however, the fault code is:
If anyone is interested; I removed windscreen wipers, complete windscreen valance, centre bulkhead assembly, plenum chamber then the fuel line to allow access to the sensor wirh a ring spanner.
qwerty Member Since: 21 Oct 2015 Location: Bristol Posts: 60 ![]() ![]() |
