Home > Maintenance & Mods (L405) > SDV8 Fuel Pressure Sensor
Mike Stote
United Kingdom 2016 Range Rover Vogue SE SDV8 Mariana Black
Hi All, anyone got some advice on changing the fuel pressure sensor, it seems very difficult to get a 27mm spanner on it with all of the injector lines all around the area?
Any tips welcome.
Thanks
Mike
Post #697440 5th Aug 2024 1:48pm
GraemeS
Australia
If you're replacing the sensor because of DTC P0088-17 then the cause is likely deteriorated wiring at an electrical connector for the sensor rather than the sensor itself, as described in LTB01083.
Post #697459 5th Aug 2024 9:35pm
andygts
it'll be the connector, I didn't bother following the guide and fitting new plugs etc, i just cleaned up the contacts and it never came back. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #697475 6th Aug 2024 9:53am
Mike Stote
Thanks for the info however, the fault code is:
P0191-85 Fuel Rail Pressure Sensor Range/Performance - Signal Above Allowable Range.
I already have a replacement sensor and was after any advice on how to remove/replace with the fuel rail supply and return lines in the way.
Thanks
Mike
Post #697483 6th Aug 2024 12:55pm
Mike Stote
If anyone is interested; I removed windscreen wipers, complete windscreen valance, centre bulkhead assembly, plenum chamber then the fuel line to allow access to the sensor wirh a ring spanner.
Cleaned all the soot/oil out of the plenum chamber, inlet hoses and the EGR fitting (extremly dirty job).
Fitted new semsor, refitted all of the above. Cleared the fault code. No problem since.
Cheers
Mike
Post #698596 22nd Aug 2024 11:30am
qwerty
2016 Range Rover Autobiography SDV8 Carpathian Grey
Post #698597 22nd Aug 2024 11:35am
