Home > Technical (L322) > 2004 L322 4.4 Petrol - Gearbox issue |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 954 |
I admire your optimism. You have the ZF 5HP24 transmission. Does the car drive fine when cold but then go into failsafe after 15 mins or so of driving (i.e. once the oil has heated up)? Does the transmission go back to normal operation once it has cooled down again? Phil |
5th Aug 2024 4:45pm |
RichardAO Member Since: 05 Aug 2024 Location: Brighton Posts: 2 |
Thanks Phil, to be honest it seems worst when cold and was like the gearbox was slipping when trying to accellerate uphill the other morning. Is the gearbox a goner? |
5th Aug 2024 7:27pm |
When the transmission goes into failsafe mode, the fault that caused it to do so is stored as an error code in the controller. Might you be able to get the codes read and let us know what the error code is?
6th Aug 2024 1:03am |
