Home > Maintenance & Mods (L322) > Where are you mounting Tom Toms?
mjdronfield
I’ve finally given in and bought a Tom Tom Go Supreme 7 inch job…. Had enough of the factory sat nav trying to take me off at every motorway junction instead of realising the motorway is fastest and rerouting from there……
Issue I have is, if I mount it at the bottom of the windscreen I can’t reach it,, to either operate or mount. The mount is very short. I don’t really want to hang it off an air vent….
What have you all done if you have one? Maybe I need to see if I can get a swan neck mount….
Cheers
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #697271 2nd Aug 2024 4:44pm
My sat nav did that, turns out it was set to avoid motorways so it kept trying to turn you off...!!! Thumbs Up Pete
Post #697297 2nd Aug 2024 7:07pm
Paul H
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
I have the same mount for mine and it is mounted bottom right of the windscreen, will post a picture later, but it keeps it from obstructing your view and its easy to reach too , its tucked up between the binnacle and the A-pillar 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #697308 3rd Aug 2024 7:58am
mjdronfield
Thanks Gents. Might have to try the right side…. Found a gooseneck mount but waiting for the chap to send me the size of the ball. Factory one is about 16mm……
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #697352 3rd Aug 2024 5:05pm
Paul H
Here’s mine
Post #697359 3rd Aug 2024 6:04pm
mjdronfield
Nice one. That is a good option then. I also found a very long mount, but the ball was 17.2mm so would have to be altered.
Ordered the other gooseneck one. See what comes….
https://www.amazon.co.uk/BuyBits-Gooseneck...amp;sr=8-4
Cheers
Mark
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #697365 3rd Aug 2024 7:29pm
Paul H
ermmm that mount isn't for the Tom Tom that you posted originally..... the earlier Tom Toms have the ball mount the later ones have a magnetic clip.....not sure that one will fit? 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #697372 3rd Aug 2024 7:55pm
mjdronfield
The magnetic clip sits on a ball mount. It’s just the ball mount I need. You can pull the mount off the Go Supreme and it has a 16mm ball, so I shall just fit it to the ball on that mount instead…..
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #697373 3rd Aug 2024 8:05pm
mjdronfield
This was a longer one I found, but the ball is 17.2mm otherwise would have been ideal…
https://www.apps2car.com/products/13-5-inc...-gps-mount
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #697408 4th Aug 2024 1:25pm
mjdronfield
The gooseneck mount I ordered came this morning. I’m happy with what it’s done, won’t need the massive long one.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #697547 7th Aug 2024 10:39am
