Home > Maintenance & Mods (L405) > Drop links and ARB on 2014 v8 Autobiography
karllap
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
Hi, I have a 2014 TDV8 Autobiography that has some slight knocking at the front when going over uneven ground.
I'm thinking that the drop links and antiroll bar bushes are an obvious place to start but not sure which I need and is it a straight forward replacement similar to other cars?
Just not sure as I have heard that I may have an active stabiliser (no idea how I check)
Any help would be really appreciated
Thanks
Post #697103 29th Jul 2024 8:12pm
knwatkins
You'll have the active (hydraulic) ARB. Dead easy to replace the bushes. Just unbolt it, drop it down and support it with a jack, replace the bushes then bolt it back in place. I did mine and a couple of years back, along with the drop links for good measure.
Part numbers:
Bushes - LR048451
Links (same both sides) - LR035489
BWI are OEM for the bushes, Delphi are OEM for the links.
Bolts:
LR050753 x 4 (M12)
LR045743 x 2 (M14)
Torque specs:
ARB link nuts 185Nm
ARB bush brackets 110Nm
ARB frame to body:
M12 (smaller) bolts - 4 off
Stage 1: 90 Nm
Stage 2: 180°
M14 (larger) bolts - 2 off
Stage 1: 140 Nm
Stage 2: 120° Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #697106 29th Jul 2024 8:50pm
karllap
That is fantastic information, couldn't have asked for more. Thankyou
Post #697115 30th Jul 2024 7:03am
JamboM3
United Kingdom 2017 Range Rover Autobiography SDV8 Santorini Black
Don’t make the mistake I did and fit Febi Bilstien ones, chased a horrific knocking noise for 8months/4000 miles.
Genuine fitted and now fine.
Post #697158 30th Jul 2024 6:00pm
karllap
It seems that there is no access whatso ever to the bushes from the top so I am assuming that you need to take the bracket from underneath it (think there are three bolts). Then I assume the bolts for the D bush holder are accessed from beneath it.
I was concerned what the bracket was for so didn't want to just remove it
Is the above correct and if so is anyone aware of any video's so I can sanity check myself please?
Post #697435 5th Aug 2024 11:14am
knwatkins
That's right, you just unbolt it and drop it down on a jack.
Here's a pic from when I did mine a while back...
Make sure to check the workshop manual. It can be found in the wiki. Kev
Post #697436 5th Aug 2024 11:20am
knwatkins
Actually, here a link to the specific PDF from my copy in my Google Drive...
https://drive.google.com/file/d/1QqLt1Uq-y...p=drivesdk
Hope this helps! Kev
Post #697437 5th Aug 2024 11:27am
karllap
That's a huge help, thanks
Post #697444 5th Aug 2024 3:20pm
karllap
What make are genuine ones or good quality ones?
Post #698241 17th Aug 2024 11:39am
knwatkins
BWI are OEM for the bushes, Delphi are OEM for the links. Kev
Post #698265 17th Aug 2024 6:12pm
JamboM3
As above. Genuine in this case meant I ordered them from Land Rover to be on the safe side as was at the end of my tether.
Post #699945 11th Sep 2024 7:19pm
