![]() | Home > Maintenance & Mods (L405) > Drop links and ARB on 2014 v8 Autobiography |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 771 ![]() ![]() ![]() |
You'll have the active (hydraulic) ARB. Dead easy to replace the bushes. Just unbolt it, drop it down and support it with a jack, replace the bushes then bolt it back in place. I did mine and a couple of years back, along with the drop links for good measure.
karllap Member Since: 29 Jul 2024 Location: North West Posts: 16 ![]() ![]() ![]() |
That is fantastic information, couldn't have asked for more. Thankyou |
JamboM3 Member Since: 28 Jul 2021 Location: Berkshire Posts: 211 ![]() ![]() ![]() |
Don’t make the mistake I did and fit Febi Bilstien ones, chased a horrific knocking noise for 8months/4000 miles.
It seems that there is no access whatso ever to the bushes from the top so I am assuming that you need to take the bracket from underneath it (think there are three bolts). Then I assume the bolts for the D bush holder are accessed from beneath it.
That's right, you just unbolt it and drop it down on a jack.
Actually, here a link to the specific PDF from my copy in my Google Drive...
That's a huge help, thanks |
What make are genuine ones or good quality ones? |
BWI are OEM for the bushes, Delphi are OEM for the links. Kev
As above. Genuine in this case meant I ordered them from Land Rover to be on the safe side as was at the end of my tether. |
