![]() | Home > Technical (L405) > Cetek charging |
RRV8SC Member Since: 02 Oct 2021 Location: SW London Posts: 164 ![]() ![]() ![]() |
I quite often leave mine in a locked garage for periods of time. What I’ve found is that if the car is locked it needs the CTEK, unlocked it doesn’t. Either way, it’s no effort. |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3024 ![]() ![]() ![]() |
It won't do any harm to leave it connected but it could be a ball ache if you come back and it's flat for some reason, so if you've got one, I'd be connecting it |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2540 ![]() ![]() |
I’ve had a CTEK connected to an old Land Rover for about a decade, only taken off very occasionally to give it a run - no issues. |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1296 ![]() ![]() ![]() |
That is exactly what it’s designed for. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3736 ![]() ![]() ![]() |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8049 ![]() ![]() ![]() |
Tie something around the steering wheel to remind you the car is connected when you return... |
