Home > Technical (L405) > Cetek charging
GrandadRob
England 2013 Range Rover Vogue SE SDV8 Luxor
Cetek charging
Going to away from home for a month. RR in locked garage. Should I leave my Cetek charger connected. ? 2013 SDV8 4.4 SE Luxor.
1960 Series 2 88 inch diesel.
1955 Series 1 86 inch petrol.
Post #696859 25th Jul 2024 9:06am
RRV8SC
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
I quite often leave mine in a locked garage for periods of time. What I’ve found is that if the car is locked it needs the CTEK, unlocked it doesn’t. Either way, it’s no effort.
Post #696860 25th Jul 2024 9:10am
dhallworth
It won't do any harm to leave it connected but it could be a ball ache if you come back and it's flat for some reason, so if you've got one, I'd be connecting it Smile 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #696861 25th Jul 2024 9:27am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
I’ve had a CTEK connected to an old Land Rover for about a decade, only taken off very occasionally to give it a run - no issues.
Post #696862 25th Jul 2024 9:50am
Gremlin500
That is exactly what it’s designed for.
Post #696866 25th Jul 2024 11:15am
Baltic Blue
Holiday mode Thumbs Up
Post #696867 25th Jul 2024 11:26am
Tie something around the steering wheel to remind you the car is connected when you return... Thumbs Up Pete
Post #696868 25th Jul 2024 12:12pm
