Home > Technical (L322) > Help needed with BMW Toolset 32 and 03 L322 DSC/ABS coding
Antipodean322
Australia 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Does anybody have an 02-05 L322 M62 V8 with ZF auto and a laptop with the "BMW tools" suite of software installed and functioning? (INPA, etc.) - Toolset 32 in particular. I have a 03 L322 with a 'cooked' Bosch 5.7 ABS ECU, and have replaced it with an ECU of the same vintage, but it is from a deisel L322 and it comes up with a coding error. To change the coding in the ABS ECU I need the 4 hexidecimal digits stored in the ECU memory, by selecting the SGBD DSC_l30.prg file (the correct file for the L322) in Toolset32 and then execute the job "coden lessen' (code write) -see attached picture which will give the correct hexidecimal digits for the V8/ZF auto. Then I can use "coden schreiben" (code write) with the hex data in the "arguments" text box for correct coding. My original ABS ECU is toast and I cant read data from it. Thanks in advance.
Post #696416 18th Jul 2024 4:42am
