Home > Technical (L322) > P0486-17 again
BRONZE BEAST
United Kingdom 2011 Range Rover Vogue 4.4 V8 Nara Bronze
P0486-17 again
Recently bought this 2011 4.4TDV8 137k miles.
Restricted performance red-light (mostly does not throw EML)
Codes read that seem significant..there's others related to doors and amplifier sound system
P0486-17 seems to be the active one and the one restricting performance.
I have ordered a replacement throttle body as this code seems to have been cleared a few times by others here. The association with the fault code seems convoluted however it has been recorded a few times.
I also have 4 boost hoses to change
Both air filters
I cleaned the MAP and sensor inside the throttle body plastic connector.
Apart from this annoying issue the car is awesome to drive.
Post #696365 17th Jul 2024 9:04am
BRONZE BEAST
Update on the EGR B Circuit restricted performance issue.
New throttle body fitted new air filters fitted That seems to have resolved the restricted performance issue for now.
Will have a look in the old part at some point.
Right now just glad to be able to drive a few miles with a bit more confidence.
Post #696676 22nd Jul 2024 9:06pm
kevinp
Be good to see if the gears have started to stip in the throttle body.
Seen a few pictures of ones that had. Might be a future fail point.
Post #696680 22nd Jul 2024 9:30pm
