![]() | Home > Technical (L322) > diesel rear shocks on 4.2 s/c |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3028 ![]() ![]() ![]() |
Likely the OE shocks for the SC are a bit firmer but if they are worn (the reason for replacing them) then new diesel shocks will still be an improvement. At the front any difference in engine weight may be an additional factor. 2012 TDV8 Vogue (L322) |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2377 ![]() ![]() ![]() |
Check that the TDV8 shocks aren't longer fully extended. |
