![]() | Home > Technical (L322) > Battery change. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7702 ![]() ![]() ![]() |
Hi,
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7884 ![]() ![]() ![]() |
Some people refer to the box next to the positive terminal as a collision related explosive disconnect device, others as a 400a mega fuse....
EvolutionUK Member Since: 03 Jun 2024 Location: Hampshire Posts: 9 ![]() ![]() |
Thanks for the reply’s. I have checked the large fuse earlier on the red positive, it is in tact.
dinosaurjuice Member Since: 11 Jan 2018 Location: Lancashire Posts: 20 ![]() ![]() ![]() |
Check all the fuses. Lots of ECUs and things have reverse polarity protection by means of a diode which will blow the fuse when powered up wrong way. MY11 4.4 TDV8 Vogue SE |
I found it was the pyro fuse and a couple of others that may have been related. The only thing I can’t seem to get working is the electric mirrors, despite the common fix of pulling fuses 11 & 24. And the BCM fuse 27 I think. They were folding and working fine, now nothing I try gets them working. Any ideas? |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1312 ![]() ![]() |
No ideas, but thank your lucky stars that's all that's |
