Home > Technical (L322) > Secondary turbo oil leak?
BBryant
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Hi all,
I think I have an oil leak on my secondary turbo, I have no black smoke on acceleration and it pulls very well. But I do have a smell of burning oil after a motorway drive (I had my oil cooler done a few thousand miles ago)
I had a look for possible leaks the other day and saw this patch when looking up through the passenger wheel arch. It seems to be to the rear of the turbo and isn't coming from the oil drain pipe. I think the oil is getting blown back onto the cat behind here and is the source of my burning smell.
Looking at the parts diagram in the workshop manual it seems likely that it is the oil feed to the turbo. My question is firstly, do you agree? And secondly how can I get to it?
Post #695804 8th Jul 2024 9:12pm
DrRob
I had a similar thing and had that turbo replaced as a result but I know of others who simply wipe off the oil and live with it.
I can recommend Glenrands for a second opinion if you need it Thumbs Up Tell them I sent you Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #695824 9th Jul 2024 10:26am
Dutchgit
Germany 2008 Range Rover Vogue TDV8 Stornoway Grey
Could be a valve cover seal that has let go a bit. If it gets worse it´ll start dripping oil from the subframe if that´d be the cause.
Post #695854 9th Jul 2024 4:53pm
