Home > Technical (L322) > RH clean air duct access 4.4 tdv8
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Hi all
I’ve had an issue with the power delivery of my car as mentioned in other threads. The primary turbo power seems to drop as revs increase and pick up again with the secondary turbo.
MAP and MAF sensors cleaned and all usual culprits to and from the doughnut have been checked and fixed.
I can also hear the primary turbo sucking air from within the car when I expect it to be quieter or inaudible.
One of the tasks I have on my list is to replace my vacuum hoses (due to age and mileage) with the thought that the variable vanes may not be operating correctly.
However, another thought is that I may have an air leak in the clean air duct from the air filter into the turbo. Access is limited (from memory) and wanted some clues on how to gain access.
I’ve looked in the rave manual as downloaded in the wiki but cannot find anything about that in the docs except for a locations guide for the filters.
Does anyone have access to any documentation related to this? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #695782 8th Jul 2024 8:37pm
Ffrr-lover
This is the part in question - LR022875
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #695783 8th Jul 2024 8:39pm
Ffrr-lover
This is the rave article image… I am referring to the duct labelled “1” that connects to the elbow numbered “5”
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #695784 8th Jul 2024 8:43pm
Ffrr-lover
This is an image of the part in question.
I see there is a connector near the turbo end of the duct. Does anyone know where that connects to?
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #695785 8th Jul 2024 8:46pm
Ffrr-lover
This link is to the same part on the 2015 l405.
This is the type of article I am looking for… if one exists…
https://www.fullfatrr.com/gallery/albums/u...RATION.pdf Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #695786 8th Jul 2024 8:49pm
MarianaWestminster
That pipe connector near the turbo end is likely for the crankcase breather hose.
The crankcase will be vented to the inlet of the primary turbo.
Post #695787 8th Jul 2024 8:53pm
Ffrr-lover
Well, that’s got me closer!
Not liking the sound of step two Big Cry Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #695799 8th Jul 2024 9:57pm
JayGee
A smoke test should reveal the leak point if you can hear air escaping. 2012 TDV8 Vogue (L322)
Post #695801 8th Jul 2024 10:06pm
Ffrr-lover
Yes, I suspect it would! Thumbs Up
I don’t have one so would need to pester a local garage to do this… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #695802 8th Jul 2024 10:09pm
