Home > Technical (L322) > Auto wipers not working after windscreen replacement
Andyyav
United Kingdom 2018 Range Rover Vogue SE SDV8 Carpathian Grey
Just had the windscreen replaced in my 2011 4.4 and now the auto wipers dont work its more of an intermittent wipe thats unaffected by conditions.
any experience of this or suggestions before i call the replacement screen company 1972 Series 3 full of character
1985 90 pick up went anywhere
1992 90 Exported
2007 L322 that was an experience
2010 D4 more versatile than a Swiss army knife, now gone
2011 L322 4.4 VSE traded in
2018 L405 4.4 VSE
Post #695642 6th Jul 2024 10:51am
madnessgonemad
I had this. They either have not put the sensor on properly or the windscreen thickness is wrong. Check your headlight sensor is working as they are the same unit.
They replaced mine and it was still erratic and then stopped working. I actually prefer the manual set to speed wipe as I always found the auto wipers a bit of a pain! So I have left it. The auto lights work fine.
I suspect it’s aftermarket non Pilkington screens
Post #695643 6th Jul 2024 11:11am
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Mine did the same but got progresively erratic to the point where they were next to useless.
I have the lights on all the time anyway so I just popped the auto wipers fuse and it defaults back to variable intermittant plus flick which is great, predictable and reliable, no issues at all since I did that.
No plan to go back to auto wipers, they're just rubbish and unpredicatble. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #695645 6th Jul 2024 11:40am
p38arover
Australia
I had to do a sensor recalibrate when my screen was replaced. Mine's a 2003 model so may be different. I used Faultmate to do the recalibrate, Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #695677 7th Jul 2024 4:29am
Andyyav
Had a look with the GAP iid but couldnt see a recalibration for the sensor, also noticed the auto lights flicking on and off a few times, windscreen company coming back to have a look, gave the impression its not the first time theyve had the issue 1972 Series 3 full of character
1992 90 Exported
2018 L405 4.4 VSE
Post #695803 8th Jul 2024 10:11pm
Andyyav
Now had the sensor replaced still not working, national windscreens are saying the sensor needs coding to the car? Anyone experienced this?
Local Main dealer quoted £216 for a re calibration?
Andy 1972 Series 3 full of character
1992 90 Exported
2018 L405 4.4 VSE
Post #705392 25th Nov 2024 12:01pm
madnessgonemad
I had the same after National Windscreens. I was actually quite pleased because auto lights still work and I always found the rain sensor was all over the place.
Much better with old fashioned intermittent wipe.
Post #705463 26th Nov 2024 11:35am
p38arover
Australia
Andy
Not coding, recalibration. A few minutes work with Faultmate. I haven't tried Testbook/T4. If it wasn't so hot outside (39 deg C/102 deg F), I'd drag T4 out of the garage and run it. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #705517 27th Nov 2024 5:35am
Andyyav
can it be done with the GAP tool? 1972 Series 3 full of character
1992 90 Exported
2018 L405 4.4 VSE
Post #705518 27th Nov 2024 5:39am
Full-fat-Lance
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Orkney Grey
I’ve been going through all of this recently with autoglass after they fitted a shatterpruffe (or whatever it is) screen at the end of September. As far as I’m aware you can’t recalibrate the sensor.
Autoglass fitted a new sensor which made no difference. In the end they wanted to confirm there was nothing more deeply wrong within the car so tested the system by taking the sensor off the windscreen and then checking things worked as they should by spaying directly onto the sensor and covering it to make it think it was dark. When it all worked as it should, they conceded that it was the screen and I’m now waiting for a OEM screen to come from the dealer. Apparently they order from the dealer as that way they can get a single screen rather than having to buy a batch from pilkington direct.
Post #706339 7th Dec 2024 7:04pm
Andyyav
I think I’ll end up with the same result, one technician proved the sensor worked as you describe above, another then came and said 100% the sensor is knackered 🤦🏻‍♂️ fitted a new sensor and swears it needs recalibration, booked into the local Indy on Wednesday with a caveat that a pilkington screen will be fitted if it doesn’t fix it
As a side note I asked Pat at GAP recalibration of the sensor isn’t available 1972 Series 3 full of character
1992 90 Exported
2018 L405 4.4 VSE
Post #706351 7th Dec 2024 9:22pm
