![]() | Home > Technical (L322) > Auto wipers not working after windscreen replacement |
madnessgonemad Member Since: 28 Aug 2020 Location: Kent Posts: 105 ![]() ![]() |
I had this. They either have not put the sensor on properly or the windscreen thickness is wrong. Check your headlight sensor is working as they are the same unit.
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 655 ![]() ![]() ![]() |
Mine did the same but got progresively erratic to the point where they were next to useless.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1559 ![]() ![]() |
I had to do a sensor recalibrate when my screen was replaced. Mine's a 2003 model so may be different. I used Faultmate to do the recalibrate, Ron B. VK2OTC
Andyyav Member Since: 13 Mar 2017 Location: Norfolk Posts: 169 ![]() ![]() ![]() |
Had a look with the GAP iid but couldnt see a recalibration for the sensor, also noticed the auto lights flicking on and off a few times, windscreen company coming back to have a look, gave the impression its not the first time theyve had the issue 1972 Series 3 full of character
Now had the sensor replaced still not working, national windscreens are saying the sensor needs coding to the car? Anyone experienced this?
I had the same after National Windscreens. I was actually quite pleased because auto lights still work and I always found the rain sensor was all over the place.
Not coding, recalibration. A few minutes work with Faultmate. I haven't tried Testbook/T4. If it wasn't so hot outside (39 deg C/102 deg F), I'd drag T4 out of the garage and run it. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
can it be done with the GAP tool? 1972 Series 3 full of character
Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 132 ![]() ![]() ![]() |
I’ve been going through all of this recently with autoglass after they fitted a shatterpruffe (or whatever it is) screen at the end of September. As far as I’m aware you can’t recalibrate the sensor.
I think I’ll end up with the same result, one technician proved the sensor worked as you describe above, another then came and said 100% the sensor is knackered 🤦🏻♂️ fitted a new sensor and swears it needs recalibration, booked into the local Indy on Wednesday with a caveat that a pilkington screen will be fitted if it doesn’t fix it
