Home > Technical (L322) > TD6 goes ok and then goes sluggish |
Ian Donkin Member Since: 17 Aug 2010 Location: A Yorkshireman in Surrey Posts: 107 |
I experienced the same (or certainly similar) symptoms in my e39 530d - I was convinced that it needed glow plugs. As they share the same basic architecture, this should be relevant.
5th Jul 2024 2:00pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7842 |
When my TD6 took a long time starting I ended up having new injectors. Garage said it will start fine if one is iffy, but not 2…..
5th Jul 2024 3:31pm |
Mali Member Since: 25 May 2024 Location: Haverfordwest Posts: 8 |
Cheers for the replies, I finally pulled my finger out and did some more in depth checks and it was indeed the in tank fuel pump that’s causing the issues.
6th Jul 2024 2:55pm |
Glad that you've got it resolved, or at least are on the way there! 2011 Range Rover Vogue SE 4.4 TDv8 |
8th Jul 2024 10:32am |
