Home > Maintenance & Mods (L322) > Rear wheel arch
Discofish
England 2003 Range Rover HSE Td6 Oslo Blue
Rear wheel arch
I've spent most of last week welding new metal into the sills and arch area on both sides of the car and apart from the final colour coat and lacquer have pretty much finished ready for the MOT re-test.
on the drivers side I noticed that there was/is a piece of rubberised strip over the inside edge of the wing is this normal and should it be on both sides
Post #695355 1st Jul 2024 3:42pm
TomC-RRV8
Check this post out has a fix for it which some of us have done.
https://www.fullfatrr.com/forum/post623129.html Current
2011 4.4TDV8 VSE
1972 MGBGT
Gone
2004 Discovery Landmark 2.5D
2003 Freelander TD4 SE
Post #695364 1st Jul 2024 5:43pm
Scouse Exile
Hi, if you mean these then yes they should be both sides.
I’ve bought some extra tubing of a similar size in an attempt to keep the arches from going bad (again)
Jon
Post #695366 1st Jul 2024 5:43pm
