Home > In Car Electronics (L322) > CCF request for RSE and Logic 7 HD - retrofit
Nickbrn
Hi all, I have retrofitted logic 7 HD and RSE to my 2010 vogue se, but I can’t get it to display on the screen. I suspect this is a CCF issue, I’m wondering if anyone has a copy of their CCF they could share with me so I can compare!
On a side note, if anyone is interested in doing the same and wants any info then just drop me a message and I can see if I can help!
Post #694902 22nd Jun 2024 9:03pm
mjdronfield
Can’t help with the ccf, but I wished mine had HD, and thought I could just swap the amp, but I heard the connectors are different, so gave up. I know some of the speakers are different too, but I was ignoring that bit 🤣.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #694905 22nd Jun 2024 9:22pm
Nickbrn
Yeah, there is quite a bit that’s different! I took the whole loom out of a Westminster. You could just put the larger front speakers in, that would probably make a decent difference!
Post #694907 22nd Jun 2024 9:35pm
muddycharles
United States 2008 Range Rover HSE 4.4 V8 Bonatti Grey
Cable
I should add there is a cable that did not come standard in the US to connect from RSE to back of headhunt (in my 2008) - you might have that issue 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #695166 27th Jun 2024 9:11pm
Nickbrn
Thanks, I’ve checked on the wiring diagrams and I don’t think there are any wires missing (I took the complete loom out of the door car aswell) I think it’s a CCF issue, there was a forum post from another forum where someone had done the same, made the same ‘obvious’ CCF changes but only made it work
By toggling some of the more obscure one’s, unfortunately they did then say what they toggled to make it work!
Post #695171 27th Jun 2024 9:30pm
Nickbrn
If anyone has a gap tool and 2010 facelift with rear screens, I would be very grateful if they can email
Me a copy of their CCF!
Post #696079 12th Jul 2024 7:34pm
