![]() | Home > In Car Electronics (L322) > CCF request for RSE and Logic 7 HD - retrofit |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7912 ![]() ![]() ![]() |
Can’t help with the ccf, but I wished mine had HD, and thought I could just swap the amp, but I heard the connectors are different, so gave up. I know some of the speakers are different too, but I was ignoring that bit 🤣.
Nickbrn Member Since: 29 Dec 2023 Location: London Posts: 8 ![]() ![]() |
Yeah, there is quite a bit that’s different! I took the whole loom out of a Westminster. You could just put the larger front speakers in, that would probably make a decent difference! |
muddycharles Member Since: 05 May 2011 Location: Miami, FL Posts: 90 ![]() ![]() ![]() |
I should add there is a cable that did not come standard in the US to connect from RSE to back of headhunt (in my 2008) - you might have that issue 2008 HSE B. Grey
Thanks, I’ve checked on the wiring diagrams and I don’t think there are any wires missing (I took the complete loom out of the door car aswell) I think it’s a CCF issue, there was a forum post from another forum where someone had done the same, made the same ‘obvious’ CCF changes but only made it work
If anyone has a gap tool and 2010 facelift with rear screens, I would be very grateful if they can email
