Home > Technical (L322) > Rear Shocks |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3052 |
Easy DIY joib. Get the Bilstein ( OE) and do both sides not just one. 2012 TDV8 Vogue (L322) |
9th Jun 2024 4:34pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7708 |
I got mine from Island 4x4. Decent price.
9th Jun 2024 6:26pm |
Jimdonut Member Since: 13 May 2024 Location: Uk Posts: 14 |
Thanks ill order this and try fit them! |
10th Jun 2024 9:50am |
Got mine from there as well. There's a thin gasket that goes on the top which you can reuse from the existing shock if you carefully remove it but I didn't fit it on mine 2012 TDV8 Vogue (L322) |
10th Jun 2024 10:50am |
Thanks ,do they have an electronic connection on them ? Does anything have to be reset |
10th Jun 2024 11:51am |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 519 |
Hi,
10th Jun 2024 12:27pm |
Plug on the top just a push fit. Nothing else to adjust but do the final torque of the lower long bolt with the wheels on the ground. 2012 TDV8 Vogue (L322) |
10th Jun 2024 12:45pm |
Front OE shocks were BWI not Bilstein. I went with Aerosus at the fronts as I was replacing the whole lot but the shocks were not realy worn so unless they are obviosly not functioning properly and the front end is wallowing about maybe leave alone or just change the bags? 2012 TDV8 Vogue (L322) |
10th Jun 2024 12:48pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2388 |
I fitted Bilstein CVDs to both the front and the rear but had to replace new Bilstein rear springs with genuine after they were ripped apart because they were too short for off-road usage. |
10th Jun 2024 1:15pm |
Ok, thanks for that feedback, I don't need yet but good to know. Fuji White / Jet 2012 4.4 TDV8 Westminster |
10th Jun 2024 4:23pm |
