![]() | Home > Technical (L322) > Rear Shocks |
Easy DIY joib. Get the Bilstein ( OE) and do both sides not just one. 2012 TDV8 Vogue (L322) |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7906 ![]() ![]() ![]() |
I got mine from Island 4x4. Decent price.
Jimdonut Member Since: 13 May 2024 Location: Uk Posts: 15 ![]() ![]() |
Thanks ill order this and try fit them! |
Got mine from there as well. There's a thin gasket that goes on the top which you can reuse from the existing shock if you carefully remove it but I didn't fit it on mine |
Thanks ,do they have an electronic connection on them ? Does anything have to be reset |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 655 ![]() ![]() ![]() |
Hi,
Plug on the top just a push fit. Nothing else to adjust but do the final torque of the lower long bolt with the wheels on the ground. 2012 TDV8 Vogue (L322) |
Front OE shocks were BWI not Bilstein. I went with Aerosus at the fronts as I was replacing the whole lot but the shocks were not realy worn so unless they are obviosly not functioning properly and the front end is wallowing about maybe leave alone or just change the bags? 2012 TDV8 Vogue (L322) |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2642 ![]() ![]() |
I fitted Bilstein CVDs to both the front and the rear but had to replace new Bilstein rear springs with genuine after they were ripped apart because they were too short for off-road usage. |
Ok, thanks for that feedback, I don't need yet but good to know. Fuji White / Jet 2012 4.4 TDV8 Westminster |
