Home > Technical (L405) > Wheel Alignment Question
Salsbury
Canada 2014 Range Rover 5.0 SC V8 Barolo Black
I just had my summer tyres fitted, and they're All Terrains. Now, the car feels like it's pulling a bit to the right, so I'm guessing a wheel alignment is needed.
So, here's my question: Is there anything particularly tricky about doing a wheel alignment on an L405? Would my local tyre shop, which regularly handles SUVs and F150s, be up to the task?
Post #694007 7th Jun 2024 12:18am
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
You need to find a good garage who know what they are doing. The L405 has to be put into ‘Tight Tolerance Mode’ using diagnostic equipment such as the GAP IID. Unless this mode is set before setting the alignment it will never be correct.
From what I hear from talking to garages where I have had wheel alignment set, the L405 is known to be tricky to get it spot on.
I also hear people say that the Hunter 4 Wheel alignment system is the best so finding a garage that use this is a good start.
I would ask your tyre shop if they understand tight tolerance mode for L405’s and if they do then it’s a good sign they are up to the job.
Post #694012 7th Jun 2024 6:16am
Salsbury
Thanks Alex, that's great info.
Post #694023 7th Jun 2024 2:25pm
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
What is Tight Tolerance mode?
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #694052 8th Jun 2024 7:44am
Alex1976
It is a setting that can be activated in IID GAP or other software that it sets the car at the optimum position to set up the alignment correctly. If not in this mode I believe the car will try to compensate for any adjustments made and effectively be working against any inputs made by the person adjusting the alignment.
Post #694054 8th Jun 2024 7:52am
West Yorks V8
Hi Gents
Do a search, on the site…. And the “How to Set it into the tight tolerance mode will pop up” 04th May 2022. Range Rover 4.4 SDV8 Autobiography
Land Rover Freelander 2 SD4
Range Rover P38 4.6
Range Rover Classic LSE 4.2 x 2
Range Rover Classic 3.9
Range Rover Classic 3.5
Post #694461 14th Jun 2024 10:26pm
JayGee
Tight tollerance mode just adjusts each corner to the precise calibrated height value rather than the +/- 10mm of normal operation. For a 'perfect' wheel alignment it's good to have this enabled but only if you have recently done a proper calibration procedure to ensure the reference heights are exactly right. Also a perfect wheel alignment is only possible if all your suspension joints and bushings are in an as new condition with no wear as dynamic loading of the suspension during use is not tested during a typical wheel alignment procedure. It's also possible to do a 'good' wheel alignment without tight tollerance mode enabled as small height variations won't make a big difference to the main values for toe, castor and camber which all have a range of values (tollerance) rather than a single perfect value. 2012 TDV8 Vogue (L322)
Post #694469 15th Jun 2024 8:10am
Salsbury
Cheers, JayGee, for the Tight Tolerance Mode crash course. I was on the brink of phoning every tyre shop in town, grilling them on TTM, and blacklisting anyone who didn't have a clue!
Post #694516 15th Jun 2024 8:50pm
