Home > Technical (L405) > 2014 Range Rover L405 C1A35-12 fault
RangeRoverandy
United Kingdom 2014 Range Rover Autobiography SDV8 Mariana Black
Hi,
Can anyone help with a fault that i am experiencing on a range rover L405 2014 model ,the fault code i am getting with a diagnostic scan is C1A35-12 , as anyone had this fault code problem and fixed the problem ,appreciate any help .
thank you
Post #693690 31st May 2024 3:05pm
Kot
Look in the WSM in the Wiki there is a list of DTC codes so C1A35-12 gives below
Reservoir Valve - Circuit short to battery
Reservoir valve circuit - Short circuit to power
Reservoir valve failure
Refer to the electrical circuit diagrams and check the reservoir valve circuit for short circuit to power. Repair circuit as required, clear the DTCs and retest
Refer to the electrical circuit diagrams and check the reservoir valve solenoid for short circuit to power. If valve fault exists, check and install a new rear valve block assembly as required. Clearthe DTCs and retest 2018 SE SDV8 4.4 Byron Blue
Post #693692 31st May 2024 3:59pm
RangeRoverandy
thank you
Post #693694 31st May 2024 4:24pm
