Home > General > TD6 Battery
Page 1 of 3 123>
S11X TT
2003 Range Rover Vogue Td6 Adriatic Blue
TD6 Battery
Hi
Had my FFRR for 2 months, done nearly 2k miles. In a morning the HDC Inactive light sometimes displays until the car starts. Took it to my Indie as the Air Suspension Inactive light came on mid week- they have reset everything and updated some software.
The HDC came on again y/day but so far the air suspension is ok.
Indie states the battery start up current is too low and suggested a new battery - worryingly they also said it may be signs of the ABS ECU faulting?
Two questions.
What is the very best battery for the RRtd6 2003. Its pointles having a car bought for all the fun of the winter if it won't start as soon as it gets a bit cold so I want the very best battery.
RE the ABS ECU where can I source one / will it repair? how can I be sure its screwed?
Othewise everything fine. Range Rover TD6 Vogue Adriatic Blue
Post #76015 13th Aug 2011 6:04am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Hi mate - I had issues with mine along with others on here. The original battery from LR is not big enough (power wise) really.
Best to go for a 110ah 920cca battery. I went for this one and had no issue so far.
http://www.carbatteryshop.co.uk/i-610-200-...I3200.html
Hope it helps Ash
2016 SDV8 AB
Post #76017 13th Aug 2011 6:58am
S11X TT
Thanks Ashley,
I've found an old thread also and that definately seems to be the battery to go for.....
Trip out to the local supplier I think. Range Rover TD6 Vogue Adriatic Blue
Post #76023 13th Aug 2011 8:31am
Europarts do the same battery under the bosch badge for £133.00
Post #76028 13th Aug 2011 8:50am
this is the one i got ..bosch s5 020 with 5 year warranty..
Post #76029 13th Aug 2011 8:54am
S11X TT
Ashley
did you buy from that company? recommended?
J Range Rover TD6 Vogue Adriatic Blue
Post #76054 13th Aug 2011 11:39am
comports
Sorry mate - Yes I did. Very easy on line and fast delivery. From memory I think it was next day. I also ordered one for Mrs C's P38 and same story.
Thumbs Up from me at least. Ash
2016 SDV8 AB
Post #76213 14th Aug 2011 5:48pm
online is good, buying locally [if you can] is better ,if, the battery develops a fault you can take get it back easier for replacement.....
Post #76214 14th Aug 2011 5:49pm
S11X TT
Thanks.
Ordered it, comes on Tuesday.
Kind regards
Post #76222 14th Aug 2011 6:22pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
don't worry about the wasting money on a ABS ECU the HDC inactive message is pretty normal when the battery gets low.
Buy a good battery charger instead. 2004 black Vogue TD6
Post #76456 16th Aug 2011 11:42am
S11X TT
Thanks for that, reassuring.
Am I right in thinking if the HDC message goes off as soon as it started then the Hill Decent IS working.
PS It only does it when starting from overnight when its colder. If I start it when its stood all day at work (and warmer) it doesnt show the HDS Inactive message.
Thanks
Post #76493 16th Aug 2011 3:15pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
Yes. I have had this message appear briefly but have tried Hill Descent switch straight after and it works fine. So it would appear to be an erroneous message when the battery is a bit low. Incidentally if I turn the key and start the engine straight away it doesn't happen. If I turn the key and wait for the heater plug light to go out (a couple of seconds) the message often appears. In the summer the car will start immediately so the delay isn't needed. I haven't had the car for very long so don't know how it will behave in the winter yet.
I used to carry a spare battery and jump leads in my old tdi300 Discovery in the event of low battery on cold mornings. May be worth considering for my FF. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #76533 16th Aug 2011 10:51pm
letsavit2
yes as mike said your hill decent is fine.
i use the "hdc inactive" message as a low battery warning. I got a new battery about a year ago but after too many short runs, camping etc it comes back and then i just put the battery on charge. 2004 black Vogue TD6
Post #76697 18th Aug 2011 9:09pm
S11X TT
Thanks. New battery arrived yesterday hopefully that will solve it.
PS I have no affilation to this company, simply trusted FFRR. Range Rover TD6 Vogue Adriatic Blue
Post #76709 19th Aug 2011 4:44am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
will that battery fit into a full fat MY2011?
Post #78034 29th Aug 2011 5:43am
Page 1 of 3 123>
