Home > Maintenance & Mods (L322) > Engine undertray insulation
toronnoRR
Canada
Anybody know if the insulation (which at this point, is all crumbly and disintegrated) on the engine tray is available? I'd like to replace mine as there's almost nothing left. On a parts diagram, it gives me a product number of 6775E.
Unless of course someone else has had any luck with installing some other type of insulation or sound deadening material?
Thanks
Anthony from Canada
Post #693572 29th May 2024 4:47pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
You have to buy the whole under tray. I choose to use sound deadening foam and cut it to size. It works okay but I would have chosen 20mm as it took a bit of squashing to get the tray back on with the 30mm installed. It’s been in place for 6 months with no issues.
https://www.ebay.co.uk/itm/163544961390?mk...media=COPY
Try and get closed cell foam if you can find that option as the above will absorb oil drips over time. TDV8 4.4 2012
Post #693588 29th May 2024 7:45pm
Range Rover L322
I cant remember the precise spec of these and which is which. Good luck.
Engine Shield KRN500130
Engine Shield Foam KRB50180
. 2012 L322 4.4 TDV8 AB low mileage - a peach
1986 V8 Defender 90 County ex-Swiss Army - Red everything....
My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775‬ (Ex LR Chief Technician)
Post #693597 29th May 2024 9:37pm
Dutchgit
Germany 2008 Range Rover Vogue TDV8 Stornoway Grey
OOF ! 75 Quid !!
https://parts.jaguarlandroverclassic.com/k...lower.html
Post #693656 30th May 2024 6:55pm
toronnoRR
Canada
Thanks guys. I'll just end up putting my own insulation.
Post #693688 31st May 2024 1:22pm
