Home > Technical (L322) > HELP! Towbar Identification!
Strobe84
Hi folks. I've got what appears to be a witter detachable towbar attached to my L322, but due to the label rubbing off I have no idea what the part number is so am struggling to identify it! Long story short, I need to tow a caravan next week, but due to the size of the hitch it'll only attach to a swan neck... helpful. Has anyone else got one of these and can help me find model numbers??
Much obliged.
Post #693065 21st May 2024 4:14pm
JamesDarby
United Kingdom 2011 Range Rover Autobiography TDV8 Buckingham Blue
Hi. You just need to swap the tow ball out for an AL-KO Extended Neck Towball to move the ball out a bit further from the plate. You can also get a packing plate that moves a standard ball out from the plate so you can then use the Alko hitch on the caravan 2011 Range Rover Autobiography TDV8 Buckingham Blue
Post #693070 21st May 2024 5:08pm
Strobe84
Thanks mate! This may actually all be a storm in a teacup... the ball itself is marked as a Maypole D17.2 S350 which seems to already be high reach! Looks as though I may already be covered.... Thanks to a previous owner of my car!!
Post #693071 21st May 2024 5:20pm
