![]() | Home > Technical (L322) > HELP! Towbar Identification! |
JamesDarby Member Since: 29 Sep 2021 Location: Rugby Posts: 25 ![]() ![]() ![]() |
Hi. You just need to swap the tow ball out for an AL-KO Extended Neck Towball to move the ball out a bit further from the plate. You can also get a packing plate that moves a standard ball out from the plate so you can then use the Alko hitch on the caravan 2011 Range Rover Autobiography TDV8 Buckingham Blue |
Strobe84 Member Since: 21 Feb 2024 Location: Worcestershire Posts: 20 ![]() ![]() |
Thanks mate! This may actually all be a storm in a teacup... the ball itself is marked as a Maypole D17.2 S350 which seems to already be high reach! Looks as though I may already be covered.... Thanks to a previous owner of my car!! |
