Home > Technical (L460) > How To Avoid Parking Brake Sticking?
aja500
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Aruba
I've just had my P460e parked up for a few weeks in the garage, when I came to back it out, what I believe is the handbrake had stuck firmly to the discs.
It took quite a few revs and force to get it to move and made quite a bang when it was eventually forced to release. I'm about to leave it parked up again for several weeks, and I'm worried that if I keep doing this it's going to cause damage.
Normally I would leave the handbrake off on a car parked up for a while, but it seems you can't with this model, what with it being electric and automatically applied.
Does anyone know what I need to do to keep the handbrake off, and stop the handbrake binding to the discs?
Many thanks
Post #692882 18th May 2024 6:07am
V8 Bob
Is it the parking brake or had you just washed it before parking up/ was it very wet? Sounds as though the brake disc pads had stuck to the disc through the initial water and then lack of use for several days. This is common to most cars in this scenario 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #692884 18th May 2024 8:41am
Fla
Ireland 2012 Range Rover Westminster 4.4 V8 Zambezi Silver
On my Disco and Golf they all auto apply the handbrake but a common theme in the industry is if you hold down the handbrake switch as in push it in the direction to release the brake and keep it held while you turn off the car this will allow you to park and disengage the auto brake.
I have to do this on the Disco and Westie if they are parked outside for any length of time. I just tested this on the Golf as its a 2021 model and it also worked. I'm nearly certain this method should work on your version of RR. Current yokes
2012 4.4 TDV8 Westminster
Subaru Sambar Pickup Tipper
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #692888 18th May 2024 10:43am
aja500
Thanks V8 Bob and Fla
Sincere apologies for the late reply. I've been in SW France for the last 6 weeks and didn't have time to check the forum before leaving, or do anything different with the car, so the parking brake is probably stuck again, will find out tomorrow!
Yes bob, I think the car was just cleaned last time when it stuck, so that may have been the cause.
Fla, I will try what you suggest and see if that works.
Many thanks once again.
Post #695562 4th Jul 2024 11:09pm
