![]() | Home > Technical (L322) > GAP IID Suspension |
It can’t detect leaks as there are no pressure sensors on the airbags or valves. The problem is either a leak or faulty height sensor. Pull the suspension control fuse and see what happens overnight. 2012 TDV8 Vogue (L322) |
JoshVogue94 Member Since: 18 Aug 2022 Location: RCT Posts: 56 ![]() ![]() ![]() |
Pulled the fuse mate and the front end still drops so definitely need to get the stuts off for inspection |
If both sides at the front dropped with the fuse out then more than likley a leak at the valve block unless you are very unlucky to have both bags develop a leak at the same time. Set the car in off road height and spray some soapy water on the bags and block to trace it 2012 TDV8 Vogue (L322) |
