Home > Technical (L322) > GAP IID Suspension
JoshVogue94
Wales 2011 Range Rover Vogue 4.4 V8 Santorini Black
GAP IID Suspension
Is there a way to use the GAP IID tool to diagnose a leak from the one of the air bags? I've recently sorted my suspension fault on the dash which was C1A13-64 by boring out the compressor silencer with a 6mm drill bit and now works fine but my front end keeps dropping every night and I've rebuilt the front valve block.
Post #692480 12th May 2024 8:18pm
JayGee
It can’t detect leaks as there are no pressure sensors on the airbags or valves. The problem is either a leak or faulty height sensor. Pull the suspension control fuse and see what happens overnight. 2012 TDV8 Vogue (L322)
Post #692482 12th May 2024 8:30pm
JoshVogue94
Pulled the fuse mate and the front end still drops so definitely need to get the stuts off for inspection
Post #692485 12th May 2024 9:01pm
JayGee
If both sides at the front dropped with the fuse out then more than likley a leak at the valve block unless you are very unlucky to have both bags develop a leak at the same time. Set the car in off road height and spray some soapy water on the bags and block to trace it 2012 TDV8 Vogue (L322)
Post #692500 13th May 2024 7:29am
