![]() | Home > General > Low Emissions Zones - L322 4.4 TDV8 |
StuMurphy Member Since: 16 Apr 2024 Location: Scotland Posts: 2 ![]() ![]() ![]() |
Did you get it escalated to the DVLA by the low emission zones team? I have the exact issue with my 2012 4.4tdv8, I've put my personalised plate on and it's now not compliant with the Glasgow LEZ. |
TomC-RRV8 Member Since: 18 Sep 2022 Location: Pangbourne Posts: 79 ![]() ![]() |
Yes I emailed the ULEZ team with a screen shot I had from the ULEZ checker when it was on its original plate proving they showed it as ULEZ compliant, and the shot of what it changed to when I put the personal plate on it they sorted it. It was the CAZ team at the DVLA who I communicated with. Current
That's exactly what I've just done now waiting for a response. Thankfully i'd done the same and took a screenshot before with the previous plate so hopefully get the same outcome.
Should do and good luck! Current
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2607 ![]() ![]() |
You will need council incompetence rather than luck, because no diesel L322 meets the Euro 6 standard Scottish LEZs require. |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 351 ![]() ![]() ![]() |
Just checked my 2012 4.4 with private reg a d it can go in any of the clean air zones apart from London and I’ve used in Sheffield, and Birmingham many times over the past few years without issue they will update the database at some point but if you check before you go and it’s ok just go 2012 Range Rover Westminster 4.4 TDV8
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7880 ![]() ![]() ![]() |
Sheffield ULEZ only applies to commercial vehicles currently.
