Home > Maintenance & Mods (L322) > Rear alignment
Sandyt
Rear alignment
Gents I cannot get the rear wheels to adjust the toe. The max movement doesnt get it in the green on a hunter system anyone any ideas- wondering if it is the control arms although I replaced them not so long ago. The reason I say this is it is as if the bush has gone
Post #692038 7th May 2024 3:58am
Pawl
There are cam type washers on some of the rear suspension arm bolts. Did you mark them & return them to their start position after changing the bushes ?
When I replaced my very worn rear arm bushes / toe control arms I had quite a lot of negative camber & well out out of spec toe in.
After changing the various bushes - after marking the position of the cam washers, I put the cam washers back in the original positions & "Bingo" everything was exactly on nominal when I had an alignment check.
I was probably very lucky - but it did illustrate how big effect the the cam washers can have - as I did have a play with them before setting them as they'd started.
If there isn't enough adjustment to get things back into spec., something could still be worn - have you checked for "play" at all bushes ?
Alternatively and far from great is that something could be bent ?
Paul Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #692205 8th May 2024 9:39pm
Anglo77
United States 2011 Range Rover HSE 5.0 V8 Stornoway Grey
@sandyt i had a similar problem and found an easy fix, see thread:
https://www.fullfatrr.com/forum/topic69374.html 2011 L322 5.0L HSE & 2018 Discovery Sport 2.0L
Previous: 2003 Discovery 4.6 V8 SE / 1990 RR Classic 3.9 V8 Vogue / Series 2A 2.25 (X2 1965 & 1968)
Post #692219 9th May 2024 12:35am
Sandyt
Thanks all
I am going to put it in to my trusty local bods I just cant be bothered getting the spanners out at least I can give him some pointers and will report back on what we find
Post #692579 14th May 2024 8:05am
