Home > Maintenance & Mods (L405) > Heath Robinson Dipstick
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
The 'oil level monitoring system unavailable' message popped up the other day. It went away and so far hasn't come back but in anticipation of failure of the sensor that's buried in the bowels of the engine, I was wondering about a way to check the oil level without the sensor. I found that a length of strimmer cord will pass fairly easily into the oil change suction pipe and into the oil in the sump. Next step is to calibrate the cord so that when it's a certain way into the pipe (a knot to line up with the top of the pipe) the normal level would be say an inch from the end of the cord. Maybe someone has already tried this or maybe it's a daft idea. .....Thoughts and suggestions on a postcard.......
Pete
Post #691428 27th Apr 2024 7:33pm
Baltic Blue
https://www.fullfatrr.com/forum/post569349...031#569349 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #691431 27th Apr 2024 8:02pm
Spridget
Thanks for that Baltic. The guitar string might be a better idea, it's a bit hard to see the level on the strimmer cord. Hoping the fault doesn't come back and I won't need it but with Landrover you never know.
Post #691432 27th Apr 2024 8:14pm
Spridget
If the sensor fails I wonder if there's a way to stop the message from coming up if the car has to be run for some time without the monitoring system 🤔. I would be happy to live without it anyway.
Post #691437 27th Apr 2024 9:01pm
