Home > Technical (L322) > N/S front driveshaft |
Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 138 |
I had the same problem, no idea why the shaft suddenly slipped out. At first I thought it was the gearbox, ZF fitted me with a new Servotronic (€3500.00) and didn't realise that the problem was the shaft not sitting properly in the differential. Then I went to another workshop and they fitted a new shaft, but in the meantime the clutch discs of the Transfer Box had been damaged. So a new Transfer Box was fitted.
24th Apr 2024 9:53pm |
Squirrel Member Since: 15 May 2012 Location: Reading Posts: 212 |
I hope it's not the transfer box! But I'll get it checked while it's in the garage, thanks for the tip! |
25th Apr 2024 11:23am |
If you did not drive to many miles with the driveshaft out it's not a problem. When this happend on mine the shaft allways went back in as soon as I slowed down to about 40 or so Km/h and I could go on but over time it was too much for the transfer box. |
25th Apr 2024 2:33pm |
I could barely drive anywhere once it popped out, I had hardly any drive and I couldn't reverse at all until everything was cold again.
25th Apr 2024 4:45pm |
