Home > Technical (L322) > 3.6 Tdv8 electrical problem and starting
msf24500
United Kingdom 2007 Range Rover Autobiography TDV8 Buckingham Blue
Hi Guys and gals
I’m hoping someone can point me in the right direction.
I have a 2007 L322 3.6 tdv8.
It’s starts and runs, then after 2/3 minutes engine fan comes on and the dash shows “ engine faulty” HDC inactive, Transmission reduced, suspension faulty”
I then cut the ignition, it will then not start again.
I have to lock it and leave 10/15 minutes then it will start again, run 2/3 minutes then the fan comes on again and all warning lights on dash.
Battery is new, alternator is new, all charging correctly.
I have cleaned the earthing points,
Checked for water ingress, and nothing.
Running out of ideas and hoping someone can help..!!!
Post #690865 18th Apr 2024 10:35pm
Triumph72
United Kingdom 2010 Range Rover Vogue SE TDV8 Ipanema Sand
I think the first thing to do is put a decent scanner on the odb port and check for codes and go from there.
Post #690885 19th Apr 2024 9:30am
