Home > Technical (L322) > 2008 SC overheats then misfire codes on all cylinders-ideas? |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 573 |
Have you checked that the fan kicks in when it gets hot?
17th Apr 2024 11:58pm |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 890 |
Plastic coolant pipes under the sc fail the thermo stat housing fails the aux electric coolant pump fails usually from being wired up wrong from the factory.......good places to start looking. |
18th Apr 2024 7:25am |
danbrown100 Member Since: 20 Feb 2024 Location: New York Posts: 7 |
Yes, the fan does come on when it starts to overheat. I had it stationary with the engine running at 3,000RPM for about an hour before it started to get too hot for the fan to cope with... |
18th Apr 2024 3:12pm |
Thanks @Gsxr1250dave, I will start to delve into those areas! |
18th Apr 2024 3:13pm |
