Home > Technical (L322) > 2008 SC overheats then misfire codes on all cylinders-ideas?
danbrown100
United States 2008 Range Rover Supercharged 4.2 SC V8 Java Black
I recently bought my first FFRR, having owned a bunch of Series, Defenders and a Disco 2.
I thought I bought well - 200k miles, 1 owner with a full LR service history and only 1 small patch of rust behind the rear wheel well. It was however a non-runner as the brake lines had rusted through and dumped all the brake fluid. The engine started and ran well and so I took the gamble...
Having replaced all the hard brake lines and bled the system, all seemed good, until having driven only about 20 miles, steam started coming from under the hood/bonnet. I stopped straight away and tried to identify where the steam was coming from (vaguely in the area of the LH side of the radiator).
When I tried to start the engine it would crank but not start until it had cooled for about 30 mins. Ran the code reader and saw misfire codes on all cylinders. Coolant level in the header tank drops by half.
So in short it starts and runs fine until it gets hot, when it cuts out and will not start. There is no pressurization of the overflow tank and no sign of moisture in the crankcase, so I think the cylinder head gaskets are still OK.
Has anyone else seen this, or does anyone have any ideas where to look? Could it be failed inlet gaskets? Any helpful suggestions?!
Post #690808 18th Apr 2024 12:48am
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Have you checked that the fan kicks in when it gets hot?
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #690810 18th Apr 2024 12:58am
Gsxr1250dave
Plastic coolant pipes under the sc fail the thermo stat housing fails the aux electric coolant pump fails usually from being wired up wrong from the factory.......good places to start looking.
Post #690815 18th Apr 2024 8:25am
danbrown100
Yes, the fan does come on when it starts to overheat. I had it stationary with the engine running at 3,000RPM for about an hour before it started to get too hot for the fan to cope with...
Post #690845 18th Apr 2024 4:12pm
danbrown100
Thanks @Gsxr1250dave, I will start to delve into those areas!
Post #690846 18th Apr 2024 4:13pm
