Home > Maintenance & Mods (L322) > Switch live on 2006 3.6 TDV8
Faversham
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Galway Green
After some guidance from the gurus here. Junior managed to kill his 09 FL fatty a couple of weeks back so we’ve bought a cheapo 3.6 TDV8 replacement which is an 06.
He’s in the process of swapping out his aftermarket Android Auto head unit and when he came to swap out the piggy back fuse from the FL to the PreFL car, he found the fuse boxes were totally different.
Would anyone happen to know the reference for a redundant switched live fuse in an 06 fatty please?
TIA
Fav Experience is the one thing you don't get until just after you need it.
2011 L322 Vogue HSE 4.4 TDV8 Galway Green/Sand - Current
2006 L322 Vogue SE 3.6 Java Black/Sand - Current
2009 L322 Vogue 3.6 TDV8 Stornaway Grey/Ivory - current but dead
2018 Discovery 5 - Gone
2017 Discovery 5 - Gone
2016 Discovery 4 Landmark - Gone
1997 P38 Vogue - Gone
1988 LR 110 V8 County - Gone
1981 LR 109 Stage 1 V8 County - Gone
Post #690521 13th Apr 2024 3:52pm
Faversham
UPDATE: We managed to sort it and hooked it into the front auxilliary poer socket fuse.
Switched live and works a treat. Experience is the one thing you don't get until just after you need it.
Post #690531 13th Apr 2024 6:16pm
garyRR
If ever in doubt, just use the heated steering wheel fuse. This is always switched live.
The auxiliary power sockets on some models stay on for a while after ignition off. 2015 Range Rover Autobiography 4.4 SDV8
Post #690638 14th Apr 2024 10:06pm
