Home > Technical (L322) > Coolant loss
tymh
United Kingdom 2008 Range Rover Vogue TDV8 Tonga Green
Coolant loss
Hi peeps.
Car’s been fine for the 18 months I’ve had it, but suddenly appears to be losing coolant.
What’s the most common cause for this please? Tym
(current) L322 3.6 TDV8 Vogue 2008 Tonga Green
(previous) L322 4.4 LPG Vogue SE 2003
If it sticks, force it. If it breaks, it needs replacing anyway.
Post #690505 13th Apr 2024 10:00am
Dolphinboy
EGR cooler
Post #690512 13th Apr 2024 12:44pm
tymh
Update… it’s losing it as fast as we put it in, but…
Engine doesn’t overheat
Heating still works
THERE’S NO PUDDLE!
We’ve just put 6 litres in… still asks for more. Tym
Post #690514 13th Apr 2024 1:04pm
tymh
…and there’s no water in the oil. Tym
Post #690515 13th Apr 2024 1:16pm
tymh
UPDATE: when I left it at the car care place yesterday, he’d said there was no puddle. I’ve just had it running in the drive and it’s leaking down the back of the engine and dripping off the gearbox. Little more reassuring that head gaskets or EGR cooler, but still wondering where and what it could be. Been under and can’t see where it’s leaking from. Tym
Post #690579 14th Apr 2024 12:00pm
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
Any one of a number of possibilities - there's a lot of cooling system stuff in the 'V' of the engine, which will all result in a leak down the bellhousing.
Take some covers off and have a good look with a torch. Fortunately the coolant is bright pink so fairly easy to spot!
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #690587 14th Apr 2024 2:14pm
garyRR
The a/c condensate pipe is in the location of the transmission, so don't get the air con dripping away confused with coolant loss.
The most common leak point on a 3.6 is the thermostat housing. It's plastic welded together and the plastic weld gets brittle. There are however all manner of places it could leak - EGRs, transmission cooler, oil cooler, radiator, hoses, split expansion tank etc etc, so the best way is to pressure test the system. You can just about see the thermostat housing with a bright torch for a quick inspection. 2015 Range Rover Autobiography 4.4 SDV8
Post #690636 14th Apr 2024 10:01pm
tymh
Thanks. Deffo a leak, as it’s orange and the coolant level plummets.
Going to ask the garage to look as I can’t see anything and it’s still under warranty Wink Tym
Post #690639 14th Apr 2024 10:08pm
garyRR
Good luck re warranty. Cooling system leaks are normally considered gradual parts degradation. 2015 Range Rover Autobiography 4.4 SDV8
Post #690640 14th Apr 2024 10:11pm
