![]() | Home > Technical (L322) > Coolant loss |
tymh Member Since: 21 Apr 2014 Location: Garstang Posts: 312 ![]() ![]() ![]() |
Hi peeps.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3226 ![]() ![]() ![]() |
EGR cooler |
Update… it’s losing it as fast as we put it in, but…
…and there’s no water in the oil. Tym
UPDATE: when I left it at the car care place yesterday, he’d said there was no puddle. I’ve just had it running in the drive and it’s leaking down the back of the engine and dripping off the gearbox. Little more reassuring that head gaskets or EGR cooler, but still wondering where and what it could be. Been under and can’t see where it’s leaking from. Tym
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
The a/c condensate pipe is in the location of the transmission, so don't get the air con dripping away confused with coolant loss.
Thanks. Deffo a leak, as it’s orange and the coolant level plummets.
Good luck re warranty. Cooling system leaks are normally considered gradual parts degradation. 2015 Range Rover Autobiography 4.4 SDV8 |
