Home > Maintenance & Mods (L322) > Seized Diff Fill Plug |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 |
The diff is a big heavy chunk of metal to heat up, so if you have a highly localised heating method like induction or an oxy torch, you would be OK if you concentrated on the plug alone IMO. I'd certainly go down that route personally.
11th Apr 2024 12:54pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1478 |
See my guide about getting the plugs undone in the wiki. You need heat, a wire brush and impact wrench.
11th Apr 2024 6:01pm |
TOMC73 Member Since: 03 Mar 2024 Location: Warwickshire Posts: 10 |
Thanks both, those ideas give me a few options to try.
11th Apr 2024 9:22pm |
