Home > Maintenance & Mods (L322) > Overfinch spoiler light replacement
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
My lights cracked and now broken. Balls.
Does anyone know what the replacement part is?
(And yes I do see the paint failing in places… that’s on the list!) Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #659738 18th Mar 2023 11:43am
KF
Finland 2007 Range Rover Vogue TDV8 Stornoway Grey
Quite frankly, looks like a standard third brake light to me.
Post #659746 18th Mar 2023 12:28pm
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Standard light Thumbs Up Thumbs Up 2014 vogue se
Post #659774 18th Mar 2023 9:14pm
Erewego
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Fuji White
Mine’s just failed too (Westminster Overfinch) and it looks like a standard Westminster 3rd light so will order one and try it
Post #690516 13th Apr 2024 2:31pm
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Standard third brake light ffrr lover. However, a word of warning, do not buy an aftermarket one from powerful UK, waste of money. If funds can allow it, get a genuine one. I bought the aftermarket one from powerful and it didn't last a year, wasn't impressed at all. Now fitted with genuine. Bit of a faff to change though unless you are 12ft tall. Take inner plastic cover off top of rear tailgate, remove the 3 bolts to remove the whole of the top tailgate trim, be careful when removing last bolt that the trim doesn't drop down and get damaged or damage the car, remove the 2 torx screws holding the spoiler on to the trim, again be careful that it doesn't drop down causing damage. Follow the wire from the light to the plug, remove plug and the light just slides out. Easy to re-assemble, better if 2 of you. When I refitted the spoiler, I put some self adhesive foam around the spoiler fixing face. This was to stop the water running down the back of the screen after washing it off or when it rained. Hope that helps you out a bit.
Post #690554 13th Apr 2024 9:34pm
Erewego
Aha - good to know !
Post #690555 13th Apr 2024 9:37pm
Barmybrummie
Took me about half hour erewego. And sorry didn't realise the original post was from a year a go. Note to self, wear glasses when reading Laughing
Post #690558 13th Apr 2024 9:53pm
