Home > Technical (L322) > Height Sensors |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 226 |
You need to quote it as a 2010 car as it’s a facelift whilst the car was registered in 2009 it is a 2010 model which the important bit from a parts point of view.
11th Apr 2024 5:30am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3255 |
Go to Advanced Factors and you can cross check your VIN number with the correct part. A car with adaptive suspension has a 6 pin height sensor. There is common consensus to only buy genuine sensors for trouble free operation if you have one that has failed but I just bought pattern part spare front and rear to keep in the car as an emergency replacement as I found out the hard way that a failed sensor can leave you stranded. 2012 TDV8 Vogue (L322) |
11th Apr 2024 7:34am |
