![]() | Home > Technical (L322) > Sounds from the wheel |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 982 ![]() ![]() |
"....and stops only after the engine is turned off"
przemi Member Since: 10 Feb 2023 Location: Warsaw Posts: 11 ![]() ![]() ![]() |
Now that you ask…strange - it is actually most noticeable when the car is standing (e.g. at traffic lights), cause while driving above 30 mph it is covered by other driving noise. |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3146 ![]() ![]() ![]() |
If it’s happening when the car is stationary then it’s not the transfer box that’s causing it.
ok, I see your point regarding the transfer case But it would rather get louder in the motorbay if it would be one of the pulley or the alternator, wouldn´t it? |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1392 ![]() ![]() ![]() |
Have you tried moving between high and low ratio a few times in case something that did not disengage fully the first time then does so? Only Range Rovers since 1988 |
Thanks, it stopped on its own |
