Home > Technical (L322) > Sounds from the wheel |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 972 |
"....and stops only after the engine is turned off"
8th Apr 2024 5:14pm |
przemi Member Since: 10 Feb 2023 Location: Warsaw Posts: 11 |
Now that you ask…strange - it is actually most noticeable when the car is standing (e.g. at traffic lights), cause while driving above 30 mph it is covered by other driving noise. |
8th Apr 2024 6:31pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3128 |
If it’s happening when the car is stationary then it’s not the transfer box that’s causing it.
8th Apr 2024 9:24pm |
ok, I see your point regarding the transfer case But it would rather get louder in the motorbay if it would be one of the pulley or the alternator, wouldn´t it? |
9th Apr 2024 7:07am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1387 |
Have you tried moving between high and low ratio a few times in case something that did not disengage fully the first time then does so? Only Range Rovers since 1988 |
9th Apr 2024 1:38pm |
Thanks, it stopped on its own |
9th Apr 2024 2:04pm |
